Chrome moly control arms
#54
Ride is improved, more responsive, less mush. Launching is improved from reduced toe in. Cornering is improved from less flex. Car accelerates and brakes better from reduced weight and less toe in. Replaces OEM rubber mounts with Poly and a heim joint.
Works for SC and TC.
In all other markets people love them.
whoa whoa. no ls support with these? arent all of the mounting and **** the same?
#56
people doubting the tubular control arms are retarded. I have had BMR upper and lower control arms on my z28 for over 5 years. never a problem. they are incredible and the weight difference was amazing.
They are not too stiff for the street. In fact I did not like the poly bushing on mine so I had bushings made out of aluminum. I re used the sleeve from the original bushing. I also drilled and tapped the control arm for a grease zerk.
I used to drive that car almost everyday on the street. No issues.
