ZZ Performance ZZ Performance is a proud Supporting Vendor
Dyno results and info on intakes
Old 03-12-2009 | 03:36 AM
  #51
Omega_5's Avatar
Oh look! A typical CSS.net thread!
This place gets more pathetic by the day.
Zooomer, keep up the good work! I'm interested to see the results.
Old 03-12-2009 | 05:11 AM
  #52
Witt's Avatar
Wait, did you compare intakes/maf housings on the same MAF cal?
Wouldn't common sense say to unplug the MAF and run speed density for comparison's sake?
Old 03-12-2009 | 08:37 AM
  #53
qwikredline's Avatar
I am thinking how glad i am to have an obsolete Redline with an awesome OEM trailblazer air cleaner, the only mod is reflective insulation. Out performs ALL the Cobalt iterations. (GM test data)
Short of moving brake lines, or sheet metal, its hard to fit anything larger in the inlet tract on a Cobalt. It takes care, intelligent installation work and some superior fabrication skills. I am hard pressed to get excited by the skill sets shown here by some posters (Oh I stripped the oil change drain plug/crushed the laminova tubes/broke my wheel studs/) or the "test results support existing prejudice" zoomer posts
Then I look at the time attack car and realise that the inlet tube was not changed, the filter housing was with a K&N in the stock location. No filter box. Hopeless for everyday use.
-T/A in 05: 312 whp with stock inlet tube without nitrous. (TVS)
-Area47 in 07: 300+ with stock bottom end and inlet tube. (TVS)
Then i re-read the zoomer posts.
Then some of the rodimus prime posts. O darn why did i sign on this am? well bro' at least your car runs now.
Originally Posted by Black SS/SC 06
So what is the intake made out of? My concern is also with design/durability. The intakes for these cars have many different places to rub and get holes in them. Was this addressed in the design?
now this is a good post! add water intrusion to design requirements...
Old 03-12-2009 | 10:52 AM
  #54
Matt M's Avatar
Originally Posted by hatrickstu
yea its awesome for trying to say "look how badass our stuff is" ....
and not testing other competitors. i understand they had the injen laying around already though. i would LOVE to see a ***** out comparison between many different intakes, and would actually gain alot of respect for zzp conducting such a comparison
Testing the Injen was important because it is by far the most common Cobalt intake on the market. As I said before, we will gladly test more intakes if someone would like us to. Send them over and we will get it done. And before anyone says that we will automatically claim our intake as the winner, I can assure you that we don't work like that. A few years ago, when we were testing 3800 intercoolers on our supercharger dyno, our intercooler significantly outperformed all others that we tested- until we had a customer ask us to test his Thrasher intercooler. We tested it head to head with ours and found theirs to cool 4 to 5 degrees more than ours under the same conditions. We have no problem reporting that another product outperforms ours if it actually does.
Old 03-12-2009 | 12:15 PM
  #55
Witt's Avatar
Originally Posted by Matt M
...As I said before, we will gladly test more intakes if someone would like us to. Send them over and we will get it done..
Matt, any chance next time you guys could test them in speed density? Not bashing but my concern is with whp of each intake so close to each other and being that you are changing the MAF housing each time its easy to have jumped a cell/row in the spark table on one of the intakes tested since the spark table's one axis is airflow calculated from the MAF. In my own tests I've found that a single degree of spark added 5whp on stock supercharger cars and could explain the differences in intake pipes that you are testing.
Old 03-14-2009 | 03:37 PM
  #56
Zooomer's Avatar
Supporting Vendor
We monitored spark and correlated AF ratio with gm/s to eliminate what you're saying could be an issue.
I think most of you are missing the point of this thread and I don't think it should have been moved to the ZZP section. We did not do a test to see if our intake was the best. I do not believe there to be significant performance differences in the tube of same diameter. The injen is 2.75 so it makes for a good test of all intakes that are 2.75 and ours is 3" so it does the same for 3" intakes.
Stock intake was only 8 WHP less than ours and 8.5 less than perfect. We consider the testing on intake tubes to be complete at this point and testing other brands wouldn't make much sense to me unless they were right there. People here would interpret the results wrong anyway. Once we saw the pipe wasn't the restriction anymore, we moved to filter and TB and blower inlet. That is where the data is more important currently.
Everyone here just wants a simple test of intakes to see 'what's the best' and you can't do a test like that. If we did the AF ratio would change, then we could test like Witt said w/o the MAF but then people would complain about it not being how they run it. All the dyno info wouldn't apply anyway to their car and we'd get into discussing one intake better than another depending on if you tuned it or not.
Old 03-14-2009 | 05:32 PM
  #57
Darkmanx's Avatar
Go dyno a tvs with a gmpp exhaust and a 3inch exhaust and tell me the difference in hp.
Old 03-14-2009 | 10:22 PM
  #58
Matt M's Avatar
If someone wants to loan a TVS, we will do it. We already have the GMPP exhaust and 3" exhausts here. Otherwise, if someone is installing a TVS on their own car and wants to come out for some dyno testing, we can do that too. I'm very pleased with our dyno testing so far. With an LS4 TB and our adapter, we are up to 262whp still running a stock exhaust. I'm thinking that 300whp should come fairly easy with single pass IC, headers, DP, exh, 2.6, and 100 octane + timing.
I'd like to add that I have personally made over 250 dyno pulls in cobalts in the last couple months. My job is fun, and it's going to be more fun in a couple months when we dial in Ryan's twincharge setup.
Old 03-14-2009 | 10:23 PM
  #59
hatrickstu's Avatar
with no cooling mods?
Old 03-14-2009 | 10:31 PM
  #60
Matt M's Avatar
Sorry, I added in single pass IC, which I forgot to mention. Good call. We will be testing the stock IC, dual-pass, and single pass against each other.
Old 03-15-2009 | 01:59 AM
  #61
Darkmanx's Avatar
Zoomer said you guys have a tvs i guess he was lying.
Old 03-15-2009 | 04:03 AM
  #62
Matt M's Avatar
Where did he say that? I know he has a larger blower, but not a TVS. Perhaps you have that confused. Or maybe he picked one up and I don't know about it.
Old 03-15-2009 | 04:18 AM
  #63
elecblue06's Avatar
glad to see this is staying civil ish..
i'd like to get some numbers like that for the 2.4 with intakes and the T upgrade..
Old 03-15-2009 | 12:26 PM
  #64
Darkmanx's Avatar
HMM right here?
Originally Posted by Zooomer
I don't know how to say this without being a dick but here goes.
I don't know what you are trying to say Area but Tim was correct and you seem to not understand how the PCM works.
For one, the PCM moves the fuel in chunks. In other words 9000hz is no different than 9030hz. The PCM only has a set number of cells to use for fueling and although the MAF is basically infinitely variable, the PCM is not.
2nd, the last cell in the PCM is the last cell. Once you hit it fueling is set to an exact point.
This right here "it plays into each other. the 11k cell is used to carry the rest of the load perse' above this. it get's done all day every day on turbo lsj's with a good sized turbo. hell i am close to the end of it with the tvs, and will be over this mark with new parts coming.
log maf vs error % or maf vs afr which ever you chose to do. do the usual maf scaling. then set the 11k cell to a desired air flow number and run with it. you are stuck at this, and it's not a bad thing. 500whp can be made, and has been made doing this. if the wastegate freaks, or boost controller freaks. hold on, because you have no built this level of error compensation into it, and can't. so you are at the mercy of these two things to work right and make life happy."
is a bunch of ****. I'm not even going to comment on it's accuracy. I'm just saying it makes not sense. It's a bunch of words and quotes from PCM tables that have nothing to do with the subject. You're posts bother me because you overcomplicate very simple ideas seemingly to come accross as knowing something that others don't. This is followed by people who don't understand what-so-ever posting pics bowing. This isn't a good thing. The readers are now less intelligent for having read the post.
But back to the PCM. So say the 2nd to last cell is 10,800 and the last one is 11,100.
The PCM doesn't use hz in 1 hz increments as I stated above. In 1/2 meg PCM boxes (used to 2004) the PCM saw frequency in 125hz increments. So it would 'click' more duty cycle every time the hz were 125 higher. If it was in between it rounded to the nearest 125 hz increment. Newer 1 meg boxes I'm guessing have more resolution. So maybe they round in 75 or 50 hz increments but I can assure you they round.
Now using above if you are at 10,800 or 10,830 it's going to give the same amount of fuel. It will round to 10,800 and use what you have in that table. If it's in between 10,800 and 11,100 it will round to some increment (whatever it's resolution is) and extrapolate from that point a number in between what you have loaded in the 10,800 and 11,100 tables. Once you get to 11,100 the PCM is done adding fuel. Doesn't matter if you flow more air, it will not add any more fuel EXACTLY as Tim indicated. There is no PCM work around, despite the rumors. You cannot program the PCM differently. You cannot change the MAX MAF. There is nothing you can do to 'fix' the problem in the PCM. You have to use an external solution to change the MAF itself and how it reads.
Now there is a slightly ghetto way to help the situation. You can program the last cell in the PCM too high. This means that once you pass 10,800 the car will run too rich with peak richness being at 11,100. Then as you pass 11,100; say 11,300 when the car is flowing more air the car is leaning out because you're moving more air without adding more fuel. Eventually you get to the right AF ratio again and then as you flow even more air you go lean. This lets you sqeak a little more out of a maxed MAF situation but nothing that would let you get to 500WHP on a MAF maxed below 400WHP.
see he said I MEANING he has one
Old 03-15-2009 | 12:33 PM
  #65
Rippin07's Avatar
actually, I think that is a quoted post of Area 47s IIRC saying that he will be at the end of the scale right away here with his new parts.
Old 03-15-2009 | 12:37 PM
  #66
laserblue2006's Avatar
yea...x this is what that was....he quotes people and post different from the way he is supposed to...
Old 03-15-2009 | 12:41 PM
  #67
Rippin07's Avatar
omfg
Old 03-15-2009 | 12:50 PM
  #68
2006blackss's Avatar
Matt, I have talked w/ Tim about my TVS, as soon as it shows up I plan on bringing it in to you guys. You can test w/ it if you want. As long as you work w/ me on my dyno tune. I will be running ZZP shorty header, downpipe, and QTP electric cutout 3". Dual pass, cobra H/E, LS4 and 3" intake. I ordered the TVS w/ 80mm and 75mm pullies to add more variables. PM me if you have any ?'s.
Old 03-15-2009 | 01:09 PM
  #69
Unforgiv3n's Avatar
Subscribed.
Old 03-15-2009 | 01:40 PM
  #70
Matt M's Avatar
HMM right here?
He also addressed Area, then put it in quotations. He was obviously referring to Area's TVS statements, yet you somehow conclude that he's a liar afterwards.
Old 03-15-2009 | 01:42 PM
  #71
Zooomer's Avatar
Supporting Vendor
Engrish owz u
  #72
Matt M's Avatar
Sounds good. I'll have Tim keep me updated.
Old 03-15-2009 | 01:49 PM
  #73
paul1588's Avatar
do u guys hav an intake for the redline yet
Old 03-15-2009 | 11:22 PM
  #74
Matt M's Avatar
Not yet, but we should have our Saturn back in the shop soon. We've just been very busy lately with a full shop.
Old 03-16-2009 | 12:45 AM
  #75
sput's Avatar
Any luck with finding a bigger filter for the injen that fits?
