F40 6-speed conversion released!
when you account for all the r&d getting this setup together. then after that, the employee time and material going in to making just one of these kits ready to be sold to public. $3,650 is a steal.
the other two options are a $10k 4t65hd swap. or the quaife 6 speed conversion which is $3,900 just itself. even if you install it, there's still time there. or the cost of having someone else pull your trans, install the gears, install trans. you're looking at $5k for the quaife.
the 4.45 is what a few hundred less than the 6speed? and is good to ~600whp. but with the 6speed you're getting 700+whp, super tight gearing, and an amazing powerband/spool with the selection of gears.... sign this guy up. haha
I feel ya, i've been running a trans i got from a junk yard for a few years now ,1-2 syncrho is pretty much trashed,lots of slop and it sounds like its grinding coffee when in neutral , the damn thing got water in it while it was sitting , didn't know it till i changed the gear oil for the first time and it was milky. So iv been planing to replace the trans anyway.
I am waiting on my kit. Should be soon. Have had my saab tranny for a couple months already. If you see a good deal, less then a grand you should pick one up. There mostly like 1300 just for the transmission.
soooo, switching to 6 speed require any tuning? Or does the ECU play dumb and think 5th and 6th gear are both 6th gear?
Or am I stupid and ECU doesnt know what gear your in. I thought it did cause it definately knows neutral
