ZZ Performance ZZ Performance is a proud Supporting Vendor
H/E Bracket Fail
Old 06-04-2010 | 08:38 PM
OneSlow_SS's Avatar
H/E Bracket Fail
today was driving to leave my sub and i hit a bump and the next thing i hear is something under my hood hit the ground..so i pull over and look under my car and here is the one side of my H/E on the ground i ended up pushing up and drove back to my house, jacked my car up and come to find out the metal piece on top with the 2 brackets the weld broke on it and the h/e was being held on by my front bumper ... took it off my car and well from the bump it tweaked it and cracked so its useless now...just a look out to everyone check those 2 brackets on top cause they dont hold that well.
Old 06-04-2010 | 08:39 PM
Rissa's Avatar
You = fail.
haha jk <3 <3 <3 <3
Old 06-06-2010 | 12:58 PM
Zooomer's Avatar
Supporting Vendor
The top brackets are not meant to hold the HE up. Post some pics, sounds like it was installed wrong unless I'm not understanding you correctly.
Old 06-06-2010 | 01:00 PM
MP Cobalt's Avatar
well if they aren't to hold it what is?
Old 06-06-2010 | 01:09 PM
ecot3c inside's Avatar
I have 2 clips on my front lip... not sure why they are there or what they are for, but I am assuming an am h/e rests on these and the top brackets just secures it?
Old 06-06-2010 | 01:18 PM
MP Cobalt's Avatar
Idk which h/e i have but it takes up all the room you have to put one in. It's a uber tight fit for my car, and the damn drain plug hangs lower than my front lip a lil so any bump i go like 3 mhp over
Old 06-10-2010 | 02:30 PM
OneSlow_SS's Avatar
here are the pics..
Old 06-10-2010 | 02:47 PM
Illini_06SS's Avatar
Did you not secure it to the bumper support with those two upright tabs? It seems very weird that that weld would fail and the two upward tabs would be unaffected.
Old 06-11-2010 | 12:49 AM
OneSlow_SS's Avatar
other friends of mine just used the front 2 tabs and not the up right ones.. u would think since those ones are there they should hold it just as well but obviously they didnt..
Old 06-11-2010 | 10:19 AM
Seriously? Those tabs are there for a reason... Full of fluid, the H/E gets extremely heavy and then add in vibrational input from driving around and you've got yourself a fatigue crack waiting to happen, and it almost always does so at the start or termination of a weld.
Have fun buying your new H/E... And make sure your friends are all aware that if they don't use the bumper support tabs that they'll end up with a H/E dragging on the ground too.
Old 06-11-2010 | 10:36 AM
shroogis's Avatar
dude, this was your fail. You should have used all of the brackets provided on the product.
you think ZZP would weld 4 brackets on if you only need to use 2 of them?
Old 06-11-2010 | 11:19 AM
Gestapo007's Avatar
lol.
Old 06-11-2010 | 11:51 AM
CudaJoe's Avatar
well I only used one of the two T-bolt clamps provided for my ZZP charge piping and its doing great.... I dont see a problem here... Oh I just cant go over 1 psi while driving, it hits my hood If I do.
Old 06-11-2010 | 11:58 AM
shroogis's Avatar
LOL @ cudajoe
The Red Line model only has horizontal brackets, but mine are holding up just fine.
Old 06-11-2010 | 01:06 PM
Gestapo007's Avatar
lol at me in the sig
Old 06-11-2010 | 06:22 PM
OneSlow_SS's Avatar
picked up my new H/E from OTTP where there front 2 tabs are MEANT to hold up the H/E.. OTTP FTMFW end of thread
Old 06-12-2010 | 04:35 PM
Zooomer's Avatar
Supporting Vendor
The outer two tabs that you did not use are welded to the HE and meant to hold the majority of the weight. I'm pretty baffled by someone using 2 of 4 brackets, saying the product broke and therefore it sucks???
the center piece is held on by epoxy and can be repaired FWIW.
the OTT HE is like our S1 and S2 units. They are made in China out of bar stock and air/air cores. All welded together. That's why their sturdy but so heavy. The problem is that they are not efficient and they don't even divide the two sides to internally cold and hot water mix together w/o even going through the HE. Not really comparable in performance to the ZZP S3 HE.
Old 06-12-2010 | 04:40 PM
MikeyB's Avatar
OP you fail. if you had installed it properly you wouldn't be in this mess.
Old 06-15-2010 | 05:06 PM
Josh@ottp's Avatar
This is false info. Our old unit used an air/air core, but it was divided inside. Our new unit uses a standard 2.5" water/air core and is also divided internally. It also has end tanks made out of sheet metal instead of bar stock. The whole unit weighs 8.4lbs.
Old 06-17-2010 | 09:45 AM
Zooomer's Avatar
Supporting Vendor
I have your core here and I don't think you've cut it open. We have. I'll post pics and see what you have to say about it.
I do appreciate you admitting these things about your old core though.
The OTT HE is definitely not made of sheet metal and your core is not properly divided.
Old 06-17-2010 | 10:52 AM
Staged07SS's Avatar
Administrator
Administrator
subd
Old 06-17-2010 | 10:59 AM
shroogis's Avatar
Zoomer, they have recently released a new core. It is indeed an air to water core like your stage 3. I just installed it on a friends Red Line. It definitely has sheet metal end tanks, but I didn't cut it open to see how it's divided.
Just wanted to throw that out there.
Josh, the new H/E looks good from what I can tell.
Old 06-17-2010 | 11:10 AM
coopercharge's Avatar
I have had mine on for awhile and no issues I just used the supplied hardware and just remember they said some mechanical knowledge required. Just have to use your head sometimes.
Old 06-17-2010 | 11:13 AM
shroogis's Avatar
A proper installation really makes a difference, eh? :P
Old 06-17-2010 | 11:14 AM
Always, you never want to half-ass a performance install. That is bad mojo.
