Im furious with zzp
pull the pipes see how far its making it through. also make sure that if you're running the factory pcv line that you put it from the valve cover to the intake and not the valve cover to the charge pipe. that would cause you to boost the crank case and send oil past the seals. double check all your lines including the return line on the bottom of the turbo. do you have it routed to the oil pan or one of the galleys that isn't allowing it to drain? also make sure that if it is trying to drain that it's not clogged up with something. oil in the charge pipes is just a bad seal, or too much pressure. but either way you're going to need to pull them to clean them
The only way it could be the turbo is if the shaft seals were leaking which would cause shaft play. Grab the nut on the end of the wheel and push it in and out. Push it up and down. It will have a little play but if there's a lot there's a problem. There really shouldn't be any in and out. A little side to side.
Also straight from bullseye they told me not to run a restrictor unless it smoked. I ran it on a Dsm with no balance shafts. Oil pressure was pretty high and never had a problem.
generally no not on the zzp kits. the feed line itself is small enough that one isn't needed. i think theres only a handful of people even using a restrictor and i don't even know if anyone on a zzp kit is. or hell even hahn or treadstone or anyone else..
#40
#41
when did i say i was gonna beat him up. or that i was acting tough. or anything along those lines? oh thats right, i didn't. i said "my 'fat mouth' would chew you up and spit you out before you knew what hit you. for the uneducated, that means i don't need to "act tough" when i can just put them in their place. he cooled off didn't he? he came to his senses didnt he? he apologized didn't he? we started working out the problem didn't we? yes, pretty sure we did. so stop acting like you know me or assuming i've done something i haven't and move along.
#43
wow, we actually had a problem, a few names flew, then we got over it and moved on, and are working to solve the problem without 300 people reporting it? this is how the site should work.
#45
Thanks and i sincerely do apologize if offended anyone i cant blame my actions on my ptsd but it makes me infuriated when someone doubts me instead of trying to help so from now on clean slate with this site ok
#46
#47
Idrinkv8 who are you and howdo you know my name lol
I plugged the middle and ran it off the passenger side of the block
