ZZ Performance ZZ Performance is a proud Supporting Vendor
Im furious with zzp
Old 08-26-2012 | 06:41 PM
  #51
S256hhrss's Avatar
Originally Posted by FasterIsBetter
Tell me something. Which pcv line did you run to your intake and did you plug off the other?
Correction to statement tapped in middle of valve cover pcv now from passenger side of valve cover
Old 08-26-2012 | 06:45 PM
  #52
BLAZIN07SS's Avatar
I'm too JDM for you
So you just routed the Pcv lines right back into the valve cover?
Old 08-26-2012 | 06:48 PM
  #53
Area47's Avatar
Rent me! per hour
**** yea. thats how i did mine.
too much crank case pressure will cause this problem. too much oil pressure will cause this problem. i seriously doubt it's the turbo.
Old 08-26-2012 | 07:03 PM
  #54
S256hhrss's Avatar
It just seems like seals to me
Old 08-26-2012 | 07:08 PM
  #55
Area47's Avatar
Rent me! per hour
before you get your nuts in a tizzy again, how about you call bullseye power and ask them what the recommended oil pressure for your turbo is. then double check what your car is putting out for pressure. you may need a restrictor. check your god damn vacuum lines as well.
Old 08-26-2012 | 07:16 PM
  #56
BLAZIN07SS's Avatar
I'm too JDM for you
We really need a picture of your Pcv lines. If it is what it sounds like, you are pressurizing the block and pushing oil past the rings
Old 08-26-2012 | 07:56 PM
  #57
EXsoccer1921's Avatar
thats what i've been getting at. if oil is "shooting out" like you say, i would venture to say its a pressure problem. not the seals, although the seals now will not be as good as they were. i've had turbos leak a bit of oil out the compressor and had some seal issues. but i've never shot oil everywhere or smoked like grandma in the back room. take some pictures of your engine bay and we'll go from there
Old 08-26-2012 | 08:03 PM
  #58
Area47's Avatar
Rent me! per hour
and after you post pics, we can come over and corn hole your sister
Old 08-26-2012 | 08:16 PM
  #59
slvrred-'s Avatar
Old 08-26-2012 | 08:19 PM
  #60
T-Man's Avatar
Old 08-26-2012 | 08:27 PM
  #61
gotboost?17's Avatar
Nothin Stock
this thread keeps getting better
Old 08-26-2012 | 08:36 PM
  #62
Omnigear's Avatar
i'd prefer not to give out my number
i cant callz j00 then >_<
oh in for the lawlz
Old 08-26-2012 | 10:12 PM
  #63
jonnymerk's Avatar
ummm now this thread also needs a pic of said sister.
Old 08-26-2012 | 10:34 PM
  #64
Fastgti69's Avatar
Interested to see what the problem was if figured out.
  #65
breds2k's Avatar
Old 08-26-2012 | 10:43 PM
  #66
Area47's Avatar
Rent me! per hour
my dick is blind.
Old 08-26-2012 | 10:55 PM
  #67
Omnigear's Avatar
my dick is blind.
ray charles status?
Old 08-27-2012 | 12:50 AM
  #68
Area47's Avatar
Rent me! per hour
**** yea. if it had eyes the world would be a totally different place.
"don't put me in there i see purple spots!"
Old 08-27-2012 | 12:55 AM
  #69
turbosmart4's Avatar
:O omg ur alive
Old 08-27-2012 | 01:09 AM
  #70
MP Cobalt's Avatar
Only if that was on Fb you sir would have 85 likes
Old 08-27-2012 | 01:34 AM
  #71
Omnigear's Avatar
or a forum that have that feature.. well this one does not have that feature.
Old 08-27-2012 | 01:35 AM
  #72
Matt M's Avatar
Send me install pics, a detailed description of what is happening, and your order number. email- stattama@aol.com
Old 08-27-2012 | 01:37 AM
  #73
Omnigear's Avatar
i blame operator error ^_^
Old 08-27-2012 | 01:44 AM
  #74
Area47's Avatar
Rent me! per hour
i don't need a like button on here to tell me im awesome.
Old 08-27-2012 | 01:45 AM
  #75
letting him get speeding tickets while logging your car is awesome enough
