ZZ Performance ZZ Performance is a proud Supporting Vendor
LDK long engine
Old 01-05-2015 | 06:45 PM
JoeRose's Avatar
LDK long engine
Is it possible to use the LDK long engine with LK9 manifolds and ECU ie replace existing engine?
Old 01-06-2015 | 01:05 AM
JoeRose's Avatar
Well this would be good knowledge for a Colbalt SS SC with a dead LSJ motor as well!
I know LDK has got variable timing but can you just lock it out and use existing timing wheel and ECU and not run DI as you have MPI in the intake manifold?
Old 01-06-2015 | 02:00 AM
exninja's Avatar
Short block is a small modification. The head would be a ridiculous amount of work and not worth it. If it's even possible.
05-28-2022 04:47 AM
06MetallicBalt
08-17-2021 04:40 PM
HEATON
10-16-2015 08:21 PM
SSLOW06
10-01-2015 08:21 PM
patooyee
10-01-2015 02:07 PM
