ZZ Performance ZZ Performance is a proud Supporting Vendor
my recommendation if you plan on buying zzp header/dp
Old 07-31-2007 | 02:36 PM
DSMissed's Avatar
It will come with 2 bolts to go between the header and downpipe....go get your own grade A bolts. It took less than a day on my car for these bolts to snap, and I didn't over torque them, cause come on - I'm a girl I'm not that strong, lol.
Other than that, I'm in love excellent buy, just save yourself some extra hassle and get a couple of better bolts.
Old 09-05-2007 | 09:24 PM
MaJ's Avatar
MaJ
Very good advice!!
I was out driving for not even 10 minutes when I snapped a bolt.
Seriously, anyone who picks this up, get better bolts.
Other then that, the product is top notch! Very clean, well made product.
Old 09-06-2007 | 12:37 PM
NightriderCobaltSS's Avatar
ok i got the gmpp header and the zzp 2.5 i can still use the bolts that are already on there right
Old 09-07-2007 | 02:15 PM
MaJ's Avatar
MaJ
Yeah, if I remember correctly the GMPP header calls for you to reuse the stock bolts, correct? If that's the case, you shouldn't have any problems.
Old 09-07-2007 | 04:27 PM
thanks i have heard , the zzp dp is gonna get me some good gains. ill update when i get it installed
Old 09-07-2007 | 05:06 PM
RedEcotecSS's Avatar
my bolts took a **** too. got new ones, and i love it.
Old 09-09-2007 | 01:36 PM
zay52790's Avatar
has anyones been leaking, my bolts broke so i replaced them, it sounded like it was still leaking so i went and tightned all the bolts, everything seems good but it still sounds like its leaking.. has this happened to anone else?
Old 09-09-2007 | 01:40 PM
what do you mean 'it sounds like it's leaking'
Old 09-09-2007 | 04:38 PM
zay52790's Avatar
well , it sounds one hell of alot louder than it should and u can hear that the sound is coming from under the car near the front,
Old 09-09-2007 | 04:53 PM
Doc's Avatar
Doc
Get underneath the car while its on and feel around the flange. Just don't touch the pipe.
Old 09-09-2007 | 05:53 PM
OrngBalt's Avatar
how do you feel without touching?
Old 09-09-2007 | 06:01 PM
zay52790's Avatar
what should i be looking for about the flange, everything seemed fine, i checked yesterday and the flange is on properly an the bolts are tight
Old 09-09-2007 | 06:05 PM
HickOverLOrd's Avatar
You should feel hot air stream out from somewhere around the flange if you do have a leak.
Old 09-09-2007 | 06:31 PM
Doc's Avatar
Doc
ask your girl, she's a pro j/p
05-28-2022 04:47 AM
ineedacobaltss
11-07-2015 03:25 PM
z28addiction
09-28-2015 01:03 AM
09-27-2015 09:53 PM
09-26-2015 07:44 PM
