is this a new intercooler pump?
http://zzperformance.com/cobalt_ion/...1187&catid=143
it looks like it would be a replacement for the IC pump. unless it's actually is the water pump. any info on it?
well whats the diffrence betwwen this and that one? is it suppose to work after the car shut off....ill post what they say
they say.
"Frees up HP by running the water pump off of an electic motor instead of the cars. Helps a lot with top end power.
Allows engine cooling with the car off."
they say.
they say.
they say.
Where are you reading that quote by the way...when i click the link, all i see is this:
"Davies Craig EWP electric water pump - Gen3 (EWP80)" along with the price and picture
did you even click on the link? You're WAAY off...
That I was. I assumed that it was the bosch pump as I can not view ZZP's site at work I forgot about the craig davies pump they sell. ZZP also has a stock replacment pump for 199. OTTP is 114. My bad lol
its a water pump for engine coolant, not the heat exchanger system. It frees up horsepower because the stock pump is driven by the engine.
