ZZ Performance ZZ Performance is a proud Supporting Vendor
New larger TB option for the 2.4 liter
Old 02-25-2009 | 03:42 PM
Zooomer's Avatar
Supporting Vendor
http://www.zzperformance.com/cobalt_...=988&catid=174
Old 02-25-2009 | 04:12 PM
1niceLS's Avatar
will this also work if your a 2.2 with a 2.4 intake manifold swap??? if so are we going to need a tune???
Old 02-25-2009 | 04:14 PM
umrdyldo's Avatar
NO tuning required? Yeah right. This would change air flow a lot I would think.
Old 02-25-2009 | 04:24 PM
Zooomer's Avatar
Supporting Vendor
Change in airflow is compensated for by the MAF. That is why you don't need to change the PCM when you drive on a cold day, in the mountains, or after installing mods like headers or ported heads.
Old 02-27-2009 | 02:13 PM
1niceLS's Avatar
so will this work if your a 2.2 with a 2.4 intake manifold swap
Old 02-28-2009 | 10:27 AM
Zooomer's Avatar
Supporting Vendor
I don't know. The change in TB size in a 2.2 may require PCM tuning as the calculated flow vs. TPS will start to be off by too much.
Old 02-28-2009 | 12:21 PM
1niceLS's Avatar
ok thanks
Old 02-28-2009 | 12:30 PM
ls1fbody's Avatar
Haz l33t wheelz.
i think there are a few 2.2's running the 2.4 manifold and TB. You may want to ask them, i know there are some drastic changes when you put the bigger LS4 Tb on the LSJ, this may or may not be the same case with the 2.2/LSJ TB swap.
Old 02-28-2009 | 12:33 PM
steddy2112's Avatar
Oh come on, common ******* sense answers this one.
Old 05-06-2009 | 11:18 PM
pat_07ss's Avatar
Are you guys working on an intake manifold for 2.4's?
Old 05-17-2009 | 11:54 AM
riko540's Avatar
bump for good question
05-28-2022 04:47 AM
01-12-2016 01:01 AM
patooyee
10-15-2015 06:11 PM
patooyee
10-01-2015 02:07 PM
importkiller
09-30-2015 08:18 PM
