Option B install help
Just got my option B kit from ZZP but I have some questions on the install. On the tank itself there is a spot on the bottom for an electrical connection of some sort. Anyone know what that goes too? Then coming off the tank there are 3 lines for tubes. One is on the bottom about 3/4 inch with no tube, where does that go? There is a small line at the top, where does that go? Then where does the line go that already has a hose attached to it? Thanks for the help.
The portion that has the electrical connections you need not worry about. You connect nothing there sincethis kit uses the same tank already installed in your car for coolant recoveery. The black hose already installed you leave there. The small tube is for your bleed line coming off of your H/E. The large connector goes inline via a t-fitting for your water to air cooling system. Did you purchase a front mount H/E as well or just using the stock? Here is a link from ZZP's website.
http://i20.photobucket.com/albums/b2...2/diagram2.jpg
Yeah that link isn't all that helpful. I also have the stock filler neck. I'm using a zzp s2 heat exchanger.
The small line on the left is the bleeder line. The one on the right goes where?
Then this line on the bottom goes where?
The line on the bottom is the overflow line between the outlet on the dual pass and the inlet on the heat exchanger pump
you splice in a "T" fitting and the "T" line goes to the bottom there
Thats because its a regular saturn coolant surge tank, thats designed for a coolant level sensor if you look on the drivers side you see a tank thats alot like it, it has that, you dont need to hook anything up to it and really theres nothing that you can hook up to it.
importkiller
09-30-2015 08:18 PM
