Received my ZZP intercooler heat exchanger, where's the instructions?
I just got my ZZP intercooler heat exchanger but it only came with 1 hose two "L" fittings and 3 hose clamps...
Shouldn't there be some bolts as well? Please let me know if I got everything and how this thing is installed
PS: very happy with the order, just need some help
Remove front bumper skin.
Install heat exchanger using tabs. They connect to the bumper support and your kit should include two bolts.
Remove one hose from the factory HE and connect to the ZZP HE, then use supplied hose to go from the unused connection of the ZZP HE to the now open port on the factory HE.
-Supplied hose clamps should be used on connections.
-RTV or teflon tape should be used on elbow connections to the HE.
-Coolant is running through both HE this way, you'll need to top off with Dexcool & water
n20saturn
09-30-2015 01:26 AM
