ZZ Performance ZZ Performance is a proud Supporting Vendor
Still waiting for a response 5 days later..
Old 08-08-2011 | 06:04 PM
gone_in_10_sec's Avatar
Waiting for a response..
Sent an email on Aug 3rd.. Not sure what to do next.
I'm not sure if I should send in my broken turbo and have them call me when it gets there??
FYI: this is my daily driver, once in a while I'll WOT her, but thats about it. Nothing major just trying to preserve her to 100k.. she at 60k now!! That includes a few back/forth trips to Florida from PA within the last 3 years..
6 days ago, I noticed a sound "Loose Belt", checked everything - belts, bolts, wiring harness, anything that could have been loose that would make that sound.. I put her on the floor stand and start her up and found this..
At first, I thought I was leaking oil from the pan (back of the pan was freshly coated), I seen a small amount of oil on the floor... WTF?? (my driveway is normally clean of oil)
Then once, I climbed under the car, I was like WTF happen here??
Fresh oil still dripping down from between the bearing/shaft housing and exhaust turbine housing..WTF!!
This kit was installed at ZZP last year around this time, then 7 months ago I had a minor exhaust leak on the exhaust manifold, the weld didn't hold up - which they replaced the exhaust manifold for free!!
My best guess is the bearing /gasket failed..
Old 08-08-2011 | 06:08 PM
Chevycobaltss3's Avatar
Look like the return is leaking.
Old 08-08-2011 | 06:19 PM
maybe.. but i felt the oil leak between the housings.. but the turbo sounds like a "Loose belt" inside.. that's sound isnt't good..
Old 08-08-2011 | 06:24 PM
Sounds like squeling bearings.....
Old 08-08-2011 | 06:25 PM
yep, like squealing pigs.. lol..
Old 08-08-2011 | 06:38 PM
Ids ure turbo journal or ball bearing....... Anywho i would even run it like that.
Old 08-08-2011 | 07:45 PM
Just checked the return line, fitting & bolts (both on the turbo and the return on the engine).. all tight - nothing loose, even checked the v-band, the exhaust bolts on turbo on the exhaust manifold. all tight..
Old 08-08-2011 | 07:50 PM
Mike08ss/tc's Avatar
Originally Posted by gone_in_10_sec
Sent an email 5 days ago (Aug 3rd).. Not sure what to do next.
Is that the s252 or the s256. Those turbos do not come with any kind of warranty correct.
That car must sound nasty with the atmospheric dump
Old 08-08-2011 | 07:55 PM
S252 - yes the warranty is for 1 year from install at ZZP, that's why i went to ZZP to get the kit installed..
Atmo dump is nuts.. friends tell me they can hear me from a mile away.. and that's in the mountains, i can imagine in the farmland plains.. that's another reason why i don't get on it, once that valve is open, my eyes are glued to the mirrors..
Old 08-08-2011 | 08:00 PM
You only get the warranty if zzp installs. I am doing my motor build this winter, going to finish it off with the s256.
I will get myself in trouble with that atmospheric dump.
Old 08-08-2011 | 08:02 PM
nizzle's Avatar
it's really only been 3 days (cant count the weekend for business contacts). Although 3 days is too long too. I'd e mail them again.
Old 08-08-2011 | 08:13 PM
klloyd's Avatar
Get on the phone and call them, it is hard to get ahold of them but keep calling and try every option thet give until you get someone.
Old 08-08-2011 | 09:11 PM
your right, weekends don't count.. just realized I sent another email today..
I've called and left a voice-mail with tech support with my name & contact info, and issues i had found with the turbo, Called on friday afternoon and this afternoon..
I've checked my email account almost hourly, both my inbox and junk email folders, to see if they have responded.. I emailed Customer Support, Matt & Turbo Tim..
Old 08-09-2011 | 11:41 AM
Got an email from Tim & Matt today, looks like time to get a new upgrade!!
Old 08-09-2011 | 12:23 PM
nizzle's Avatar
wut are they going to do?
Old 08-09-2011 | 02:37 PM
new uprgrade?????
Old 08-09-2011 | 08:08 PM
It's not they are going to do, it's what I'm going to do..
new uprgrade?????
The warranty on the turbo expired two weeks ago (7/27), so with that in mind,
going to send the TC to Bullseye' to get repaired.. but may get the S300 series TC w/ new billet wheel..
Supercharged06SS
12-11-2022 05:47 PM
06MetallicBalt
08-17-2021 04:40 PM
10-13-2015 10:32 PM
maliki778
10-01-2015 08:39 PM
importkiller
09-30-2015 08:18 PM
