ZZ Performance ZZ Performance is a proud Supporting Vendor
Supercharger Spacer Plate? Questions?
Old 02-19-2009 | 09:10 PM
leviticus88's Avatar
http://www.zzperformance.com/cobalt_...=970&catid=143
If I purchased this, would I need a new gasket?
Does it include plugs to fill the 1/8 npt holes?
Are the 1/8 npt taps on the front (forward side of the intake manifold) or back (Rear side of the intake manifold)?
Availability?
Any thoughts on using this for nitrous?
Thank you!
Old 02-19-2009 | 09:25 PM
matchhead's Avatar
ive got one, i use it for meth...mine was just a spacer though, drilled and tapped my own holes. it doesnt look like you would need another gasket, looks like its "built in" not sure though...ask them
Old 02-19-2009 | 09:34 PM
I was waiting for someone to make one of these again. I never have liked the idea of spraying through the blower, especially nitrous/fuel.
Thanks for the help!
Old 02-25-2009 | 12:56 PM
Zooomer's Avatar
Supporting Vendor
It comes tapped with 2 NPT holes. It also comes with plugs or a vac line fitting depending on your drop down selection. It is Oringed so it doesn't need a gasket but you'll use one supercharger gasket.
01-12-2016 01:01 AM
brandon04
10-21-2015 08:04 AM
goaliemo
09-28-2015 02:37 PM
SlowSaturn
09-28-2015 12:03 PM
z28addiction
09-28-2015 01:03 AM
