ZZ Performance ZZ Performance is a proud Supporting Vendor
View Poll Results: What will you get for ZZP Black Friday?
TC kit
20.63%
FMIC
15.87%
Down Pipe
14.29%
Lower Pipes
6.35%
Upper Pipes
4.76%
Exhaust
14.29%
Mounts
9.52%
Clutch
6.35%
Clutch
3.17%
Shift Linkage kit
4.76%
Voters: 63. You may not vote on this poll
Top TEN ZZP item on Black Friday?
Old 11-22-2010 | 06:52 PM
gone_in_10_sec's Avatar
Top TEN+ ZZP items on Black Friday?
Just wondering what everybody will purchase on black friday?
1. TC kit
2. FMIC
3. DP
4. Lower pipes
5. Upper pipes
6. Exhaust
7. Mounts
8. Clutch
9. Clutch Rod
10. Shift Linkage kit
11. 78# Valve Springs
12. Brake Lines
13. AEM Intake
14. e-Manifold
15. TC
16. Wiseco LNF pistons
17. Coil Cover Plate
18. Head [ZZP Ported]
19. Gauge Pod
dont know how to change the poll to update it..
Old 11-22-2010 | 07:21 PM
b00sted06ss's Avatar
long tube header for me
SOHC24powa's Avatar
Lnf ecu for more bro status.
Old 11-22-2010 | 07:22 PM
BPacak's Avatar
Vtec Rep
catless dp, and trying to find a deal on a k&n intake
Old 11-22-2010 | 07:24 PM
ecot3c inside's Avatar
#78 zzp valve springs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 11-22-2010 | 07:27 PM
chrisjaldin's Avatar
I vote for that.
Your poll list is too small. xD
Old 11-22-2010 | 07:29 PM
DoMiStIc_RuSh_06's Avatar
Hoping to get a good deal on their mod pipe so I can switch back and forth between catless and catted easily.
Old 11-22-2010 | 08:29 PM
cmiller8006's Avatar
At this point, these are the given. I am sure I am missing some, but if there for sale I will buy them.
1. New mani
2. downpipe with v band
3. Either 44 or 46mm wastegate
4. LNF wiseco piston
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
Need mounts. Wheel hop is kiling my car!
Old 11-22-2010 | 08:30 PM
Empty Pockets's Avatar
stage 3 kit and long tube
Old 11-22-2010 | 08:33 PM
REIGN SS's Avatar
Original Hayden Fanatic
Please use the 2.0 LNF tech section for technical discussions related to the vehicle.
General discussions about vendors product offerings should be made in the appropriate vendors section of the forum.
Old 11-22-2010 | 08:38 PM
sorry bro didnt know.. you can change it to the appropriate vendors section of the forum..
Plus how do you update the poll to add more items?
Old 11-22-2010 | 08:46 PM
REIGN SS's Avatar
I already moved it.
I'm not sure if Members can edit polls, if so there is a link at the top of the poll on the right hand side
Old 11-22-2010 | 09:04 PM
I already moved it.
there is no link to edit the poll..
Old 11-22-2010 | 09:17 PM
I know some said they would like to see interceptor gauges as well as triple gauge pods.
Old 11-22-2010 | 09:25 PM
wambo92's Avatar
I want dual interceptors!
Old 11-22-2010 | 10:57 PM
07cobaltguy's Avatar
i want a new turbo manifold. i cant get the bolts on mine and puts the turbo too close to the trans mount. If they had one on sale id grab it.
Old 11-22-2010 | 10:59 PM
What kind do you have now?
Old 11-22-2010 | 11:02 PM
mperez's Avatar
control arms or stage 2 clutch
Old 11-23-2010 | 02:20 AM
Shaun927's Avatar
2.4 stage 3 kit!
Old 11-25-2010 | 12:19 PM
i have vulcan turbos garbage. the welds are all cracking, the turbine housing is too close to the thermostat housing and trans mount so my DP just barely clears. and my coolant temp will randomly jump to 350*F for a quick second then back to normal on long trips. I could barely get the bolt onto the manifold to bolt it to the head, i ahd to take ther crossover tube off. poor poor design and execution.
Old 11-25-2010 | 06:33 PM
Well I already had ZZP's once, but sold it. Very good welds and design and bolted right up. Good choice.
Old 11-25-2010 | 06:41 PM
Gestapo007's Avatar
lower pipe with MAF relocate
Old 11-25-2010 | 06:58 PM
Render2009's Avatar
7 more hours!!
Old 11-25-2010 | 07:04 PM
RazzKazz's Avatar
i neeedddd mounts and Axles plz :-)..
