ZZP Coldside Piping
ZZP Coldside Piping
Alright i have a tial 50mm bov on my car right now and im going to buy the zzp coldside piping. Im wondering which option i need. I already have a block off plate i need to install so im not sure if i need the first or second option. Any help would be appreciated
You need the option with the BOV flange if you're talking about the upper.
Cobalt & Ion ---> ZZ Performance
Hang on. paintballer do you want a new hot side to use with your bov? That is what zoomer posted, but you said cold side. ZZP suggest that you relocate the maf if you go with a bov so you need what I listed if your wanting a cold side, which is the pipe from intercooler to the throttle body.
bump...curious as to what option i would need on the coldside piping. w/o the maf pad or the option with the pad/block-off/extension. Does the first option come the the extension and block-off? and enlighten my newbness..what is a maf pad?
