ZZ Performance ZZ Performance is a proud Supporting Vendor
Zzp/Electrical experts please step in, Zzp 2 bar map question
Old 07-23-2010 | 08:12 PM
EcoTecDriver's Avatar
I need to know if the ZZP 2 bar MAP for the 2.4L will work with my L61 2.2L
there seems to be only one difference between the wiring which is the 2.4L has a 5Volt reference 2 and the 2.2L has a 5Volt reference 1
are they the same?
LE5 MAP:
* (OG/BK) Orange/Black - Low Reference
* (L-GN) Light Green - MAP Sensor Signal
* (GY) Gray - 5 Volt Reference 1
L61 MAP:
* (GY) Gray - 5 Volt Reference 2
Old 07-23-2010 | 08:23 PM
HunterKiller89's Avatar
they should be the same, as they are both 5V reference wires....
no idea what the number after signifies, but 5V is 5V regardless of the source
Old 07-23-2010 | 11:46 PM
thanks Hunter you have been a lot help
bump for a doublecheck
Last edited by EcoTecDriver; 07-23-2010 at 11:46 PM. Reason: Automerged Doublepost
Spanky's Monkey
03-07-2016 07:06 PM
lendsley
09-22-2015 11:48 PM
Shane H
09-19-2015 12:28 PM
Knightwolf
09-12-2015 12:02 PM
SiloGM
09-08-2015 12:04 AM
