ZZ Performance ZZ Performance is a proud Supporting Vendor
ZZP PCM Install
Old 12-03-2010 | 06:08 PM
SOHC24powa's Avatar
ZZP PCM Install
ordered it black friday, got it wednsday, installed it 5 minutes ago.
it took 30 minutes(3x10minsecurity things). i have gms1 sensors and no 1st boost reduction, set at 22psi.
took it for a drive:1st gear; immediate wheelspin with some hop at the end(im gonna need the ottps2 upgrade), short shifted to 2nd; spun til about 5700 when i short shifted to 3rd;rolled into third and it brook loose so i let off.
its like 40* out, and my brother said i was right 25-24psi. i watched the gauge on a couple pulls and he wasnt lying lol. im either getting matt to tune over in january or im getting john at six sigma to tune over.
discuss.
Old 12-04-2010 | 10:38 AM
beast10007's Avatar
for one the stock boost gauge sucks!
I have a 24psi tune from them and it is also the same as what they run so more then likey you got this tune. I have had it for 6,5xx miles and I am running strong
Old 12-04-2010 | 02:34 PM
SOHC24powa's Avatar
UPDATE:
got on a dynojet today. afr was 13.0 flat. boost peaked at 28psi?!!?!?!?!?!? creeped down to 21ish after 4k.first couple pulls were 285hp/175tq(i think its time for a new clutch lol). last pull i put down 285hp/355tq. i think im gonna go easy until january lol.
Old 12-04-2010 | 11:40 PM
beast10007's Avatar
weird my numbers are in my sig on a mustang
My afr is a max of 13 with a avg of 12.7
boost spike is 24.7psi
Old 12-04-2010 | 11:47 PM
GM COBALT SC SS's Avatar
Originally Posted by SOHC24powa
UPDATE:
horrible horsepower numbers. you are gonna want to run 28 psi as a daily tune from what ive read. you probably shouldnt go over 24 psi on stock internals. you need a trifecta tune man with some logs or hp tune or something. a canned tune for your tc is a bad idea id say.
edit horsepower at 285 isnt horrible but ive seen guys getting over 300 at 24 psi
Old 12-05-2010 | 03:26 AM
SOHC24powa's Avatar
It's just the base tune, only power mod I have is a downpipe. I'm sure once matt tunes it, I'll be in better shape.
Old 12-05-2010 | 03:45 PM
05RLS2's Avatar
So whats the point of even going with the ZZP PCM to begin with if you have to retune it? Not specifically saying this to the OP, but it seems that many people get these and after all is said and done, end up having it retuned with the HPT, etc because of idling problems, sputtering in higher RPMS, other
Old 12-05-2010 | 04:37 PM
SOHC24powa's Avatar
Having a second ecu. To switch back for warranty work. Just a peace of mind thing I guess.
Old 12-05-2010 | 10:11 PM
not abad deal if your still under warranty
Old 12-05-2010 | 10:12 PM
troyss's Avatar
Damn I need to get an tc balt
Old 12-05-2010 | 10:25 PM
beast10007's Avatar
yes u do
05-28-2022 04:47 AM
01-12-2016 01:01 AM
nathan112i
09-30-2015 08:12 PM
09-27-2015 09:53 PM
09-26-2015 07:44 PM
