ZZP Phenolic IM spacer
well i broke down and purchased this a few weeks back before i decided to sell the car. installed it yesterday. it actually works as advertised. instead of the intake manifold heatsoaking and basically absorbing the engine heat it stays cool. normally if i turned off the engine and let the car sit the IAT2's would reach the same temp as the engine coolant temp and i would have to drive around and get some airflow to get the temps to drop. now the temps sit about 20 degrees above ambient and only go up about 10 degrees once the engine stops running which is a huge difference from before. honestly couldn't be happier with this product.
Just got one of these. ****** works so good! Iat2 stay within 30* of iat1 while idling/staging where before I would see 50*+ also when you turn the car off, it doesent heat soak anymore at all.
