ZZ Performance ZZ Performance is a proud Supporting Vendor
ZZP releases new axle options!
Old 03-26-2009 | 11:51 AM
Zooomer's Avatar
Supporting Vendor
http://www.zzperformance.com/cobalt_...1000&catid=146
The strongest solutions, at the best price with the best warranty.
Old 03-26-2009 | 11:54 AM
invisible's Avatar
Nice. Not bad for stockers.
Old 03-26-2009 | 11:55 AM
Luv2Race's Avatar
Nice, Im not sure how much Hp my cars going to be pushing soon so I dunno which axles would work best. I do know the stage 3 seem a little high for $999
Old 03-26-2009 | 12:12 PM
Zooomer's Avatar
Supporting Vendor
Originally Posted by invisible
Nice. You have a misprint though.
-Lifetime warranty again center shaft breakage.
fixed, thanks.
Old 03-30-2009 | 05:22 PM
andrew97's Avatar
so the stage two is just a direct fittment in place of the stock ones, and its capable of 500 horse??...sounds good to me for that price@
Old 03-30-2009 | 05:40 PM
2006blackss's Avatar
can I just buy one. I have a leaky DSS stage 2 axle. Don't really wanna replace both of them
Old 04-13-2009 | 01:31 PM
SC07's Avatar
the stage two's look nice,
basically better DSS stage two's
i have heard of leaking DSS's and DSS's with bad splines causing trans failures.
so these zzp axles are looking real fresh.
i have some questions though, how have the stage two's been tested, are they for sure good for 500hp?
i see that they have a warranty on center bar breakage, but what about the splines?
Especially on the trans side I am worried after seeing some of the havoc the DSS's have caused.
Old 04-13-2009 | 01:39 PM
Darkmanx's Avatar
wow great price.
Old 04-13-2009 | 01:44 PM
JUICED_SS's Avatar
subscribed!
Old 04-13-2009 | 01:49 PM
stage2cobaltss's Avatar
dang... ott just came out with theirs for 399 but their the same? but 249 from zzp??hhhmmmmm
06SS ALL DAY's Avatar
are you serious... i'm so buying these in June FOR SURE! thank you zzp
Old 04-13-2009 | 01:55 PM
Zdeuce4's Avatar
wut about 2.4s??!!
Old 04-13-2009 | 02:09 PM
Rodimus_Prime's Avatar
good deal!
Old 04-13-2009 | 02:11 PM
zay52790's Avatar
damn thats a good deal, the stg1 looks just like the ottp stg 1, exept its alot cheaper, if i snap my stockers again anytime im definately upgrading to these
Old 04-13-2009 | 02:21 PM
phatnackySS's Avatar
sweet deal, i broke my axle day 2 of owning my SS tiring to find the best way to launch, feather the clutch at 3k had some wheel hop and the axle snapped in 2 places . i haven't tried launching my car since. i know wheel hop is bad, but wow i i thought it could take more than that, my last car was a ford escort zx2 and it took 5k clutch dumps with nitrous out the hole for 3 years with no problems.
i kinda figured the axles were designed to break...
is there a core charge ? thies will be my next upgrade
Old 04-13-2009 | 03:58 PM
Zooomer's Avatar
Supporting Vendor
No core charge on any of the axles.
Our stage 1's are the exact same axle as OTT, just a lot cheaper. We have not tested them for WHP, I'm guessing OTT is guessing at 325. Time will tell.
Our stage 2's do not have spline warranty because it's better material but the same size as stock. We have run them at over 400WHP without issues. Soon over 500WHP.
If you are overly concerned, the stage 3's are the only way to get larger splines and an unconditional warranty on everything.
Old 04-13-2009 | 04:07 PM
Area47's Avatar
Rent me! per hour
axles don't break from whp.
same thing with clutches
Old 04-13-2009 | 04:11 PM
red_line_cobalt's Avatar
watching
Old 04-13-2009 | 04:53 PM
ebristol's Avatar
Stage 1 should be fine for most people. You need to be very careful when your transmission becomes the week point in your drivetrain.
Old 04-13-2009 | 04:59 PM
Darkmanx's Avatar
Zoomer you say these are the same as ott ones but they say it's not
Old 04-13-2009 | 11:51 PM
steddy2112's Avatar
Thought the same exact thing
Old 04-14-2009 | 12:06 AM
distillion's Avatar
one of my Dss axles are leaking...got no warranty left.
hrm...
Old 04-14-2009 | 08:50 AM
Zooomer's Avatar
Supporting Vendor
Very true but it's the only way that customers understand things. If we started talking about vehicle weight, torque, traction, etc things would get confusing. The only real way to test is to do a torque to failure test with load readings are various degrees of twist. ZZP has and often does this type of testing but we are mocked for being smart on CSS.net so it's easier to keep the explanations simple and avoid people posting FTL and "my axles 'feel' stronger', etc. It's frustrating. Here's an example of the testing we do to determine this type of strength:
You generally won't see other companies doing this type of testing. It's much easier to make up false HP numbers or give colorful descriptions that really don't give any real information. I hope that when we start racing and as time goes on, people begin to appreciate the scientific methods.
We added these to the site yesterday, how would they know what we're selling?
There is much I'd love to say about a lot of products used on these boards but hostile customers, moderators, and other vendors have forced me silent, so much information cannot be shared. On the axles, OTT says they aren't the same, I say they are. Order them both if you are curious and post your results. I'll give you 110% of your money back if you return ours.
Old 04-14-2009 | 10:26 AM
freakta's Avatar
def check these out later.
Old 04-14-2009 | 12:16 PM
distillion's Avatar
and these wont have any annoying leak issues like DSS?
