zzp stage kit
zzp stage kit
i just have a question...if i buy the zzp stage kit (3) i kno i'm gettin a tuned pcm with it but do i need an ECU reflash or does the pcm take care of that and how do i go about gettin the ECU reflash *if needed?..also i have a friend that wats the stage 4 kit...is it available w/o the header an downpipe? if so wat is the new price?...i guess it was a few questions..hopefully someone can help..thanks i'm anxious to purchase one so the sooner the answers the sooner my purchase..thanks guys
thanks guys finally a reply...any place that does a dyno tune can reflash my ECU...i assume i can't take it to the dealer to get them to retune the ECU?...i thought i was good to go but i am makin sure i have all the angles covered b4 i buy something
no the dealer will not tune your car, you will have to find someone that will do the tuning for ya. most performance shops do tuning. what your going to get with the zzp kit is a new pcm, and you will just have to swap it out for your stock one. plug and play man
wat good is the wideband exactly...FYI here's current mods, Injen CAI, poly trans mounts, Tenzo Springs, ASA wheels (no performance gained ) lol....DC Sports catback 2.5 ..i kno i needa finish my exhaust an i'm plannin on gettin a heat exchanger as well...wat good would a wideband do me if i cant tune myself? an noone within an hour tunes either so hence the reason i'm buyin the pcm so i can go back to stock for warranty also
aem is the wideband i run... and i love it. i also bought the CA dual gauge pod and so that i could run the stock boost gauge, and then the AEM wideband.
the wideband will tell you how rich or lean your running, and with a canned tune, thats not a bad idea. if you see it spike lean, get off of it.
yea i'll have to get wideband eventually then...i'm prolly gettin a zzp downpipe anyway so i'll get the bung put in...i trust zzp isnt gunna kill my engine tho....i've not heard any bad things about them so i'll give em a try an test em out in there goodness...hehe
